N-Gage application updated to 1.20(1459)
9 replies · 29,593 views · Started 08 May 2009
The N-Gage application has been updated to a new version. There don't seem to be any major changes, so it could just be a bug-fixing release, but so far it works identically to the previous version. If you want to update, open your N-Gage application, select "Options" and then "Check For Updates", then follow the instructions. Note that after installation the N-Gage icon may get moved from the front page to the Applications folder, you can move it back to the front page by using the instructions below.
Hi..i have a Nokia N85 and a N96 and i cant install the new ngage update on my N85..i get an ''unknown error-5'' message before it finish installing...can someone help me, i have to say that i did install the update succesfully on my N95!!!
Inconfundible wrote:Hi..i have a Nokia N85 and a N96 and i cant install the new ngage update on my N85..i get an ''unknown error-5'' message before it finish installing...can someone help me, i have to say that i did install the update succesfully on my N95!!!
That's strange it installed on my N85 no problem. that error has occurred with ngage before though on my N95- make sure your access point names don't have punctuation marks ie .,;!''@! etc in them, for some reason it stop ngage working..
Tzer2 wrote:What's the problem? Maybe we can help?
I click on the app, the screen goes blank and then I get booted back to the main menu screen.
Every. Time.
All help appreciated! 😊
That's happened to me occasionally after I've done a firmware update. If I remember right I normally try updating again through the PC software updater without restoring settings.
Also, which phone are you using? Some models don't work with the main version of the app and need their own special version.
Thank you, I think HTC mobile phone fashion design, precision process quality, satisfying the screen and the bell is other brand mobile phone does not have, I like his shell is very good, feel is good, you might as well go to have a look, look have everyone like shell
