Clock too slow!
5 replies · 9,617 views · Started 08 May 2009
Anyone experiencing slow clock on 5800? I seem to be loosing about 3 minutes a week.
Also any way I can uninstall the voice Recorder application and reinstall it? It randomly stops recording after a few minutes.
alal39 wrote:Anyone experiencing slow clock on 5800? I seem to be loosing about 3 minutes a week.
Yes, I noticed it yesterday, mine was about 5-6 minutes slow and I've had it about 2-3 weeks.
I updated to the v21 firmware yesterday though somaybe that will help??
I use Automatic time update and my clock has never been fast or slow.
Menu - Settings - Phone - Date and Time - Automatic time update - ON
when i set the automatic time update on,it goes back 2 hours.dont no wat do do.
can i resolve the clock slowing down problem if i do any software update
vlinus wrote:when i set the automatic time update on,it goes back 2 hours.dont no wat do do.
In that case, you have the handset set to the wrong time-zone. (Settings->Date & Time->Time-Zone)
Correct the time-zone and then enable automatic time updates, should keep your clock accurate.
