IR On Fujitsu Notebook
3 replies · 2,199 views · Started 01 March 2003
I bought a Fujitsu note book with IR and os is Windows XP , installed PC suite but cannot connect my Nokia 9210i thru IR and it doesnt have a serail port
Anyone can help,
Hi Shanan.....
I think the problem not that much diffecult....... if you have USB port you can get connection between the communicator and the notebook through an infrared cable......and this kind of cable is available in the market.........
also, if you don't have USB port .........and your notebook provid pc card slot.......you can install USB PC card........
