My N85 has become very scratched, decided I need to start a fresh, get a new face place and slap a good quality screen protector on it immediately after fitting!!!
The only thing is, I have been browsing the internet and the only vendors are ones I have never heard of, I don't know whether to trust them, I'm also not much of an ebayer
Just wondering if anyone can recommend a reputable company that has one in stock (preferably based in UK)
I really need some help, it would be very much appriciated
thank you
there are quite a few decent ones on ebay, there are also a few that offer replacement sliders which I used to replace mine and it was top notch for about 15 bucks US and it was just as easy to do as the big sticky topic of wobbly slider fix here's a few linkshttp://cnn.cn/shop/nokia-sliding-mechanism-p-3830.html
http://www.klc.fi/en/products.php?g1=40c410&g2=1d095a
http://www.cellulardr.com/products.php?cat=483
http://www.ipmart.com/main/product/Slide,Board,for,Nokia,N85,Phone,black,,Original,new,,103532.php?prod=103532
twinpeaked wrote:My N85 has become very scratched, decided I need to start a fresh, get a new face place and slap a good quality screen protector on it immediately after fitting!!!The only thing is, I have been browsing the internet and the only vendors are ones I have never heard of, I don't know whether to trust them, I'm also not much of an ebayer
thank you
Hi
I got one from http://www.accessorylink.co.uk/product.asp?ProdID=35128&CtgID=33064 it was delivered next day.
just noticed its currently out of stock, would reccomend them though give them a call to see when its back in stock.
I too need one of these! thanks for this, didnt know they existed 😊
Any idea how to remove the old one though? ive taken the 4 screws out and it wont budge
shibby wrote:I too need one of these! thanks for this, didnt know they existed 😊Any idea how to remove the old one though? ive taken the 4 screws out and it wont budge
The cover is just glued on.
take the 4 screws out and you have to pry gently around the underside of the slider around the lip of the face. your best bet is to locate a disassembly manual.
here are some other sites and ebay has some good ones to.
Does anyone know if the slider mechanism (and assembly) is similar to the
N95?
Also the OLED is it sensitive to touch when you finally get the cover off?
Many thanks
