Im new to the new nokias, in the past i used to be a nokia freak but switched to blackberry ever since. So my question is, can i customize the home screen where the icons are on top in a horizontal row, and rid of the calendar below it? I see alot of screen shots of the E71x and the home screen is way different than mine.
Customizing home screen on E71x
Yes can customize the shortcuts along the top row. Menu>Settings>Config>General>Personalization>Idle Screen Mode>Shortcuts Yea that took me a little bit of menu searching when I did it 😊 . You can also change the layout of the main screen and menus by going to ....Personalization>Themes> then Menu View or Idle Screen. I hope this helps.
along these lines.....i kinda dig the analog clock on the home/idle screen but can't seem to find out how to display that on my e71x. is that option only available on e71 or is it a difference in OS versions?
