I have a N96 and use NSeries PC Suite (content copier) to back it up. I only select notes, calendar, contacts. I do not select "user files".
Why do I wind up with a 360 Meg file on my PC? Any idea how to make this smaller? Why is it so large anyway? Any ideas?
Hi Yokie Kuma,
What you can do is install Nokia OVI Suite 1.1.311 from
http://www.ovi.com/services/support/nokiaovisuite?id=services_support_nokiaovisuite_d0e61&lang=en-US
or
You can download Nokia PC Suite 7.1.26.0 from europe.nokia.com/pcsuite
NSeries PC Suite was replaced by Nokia OVI Suite long back 😊
You can check this in any of the above 😊
Thank you. I'll give it a try.
