I've got an N96 using the 12.* firmware, and I'm trying to update to the 20.* version.
The NSU begins the update, turns the phone off and then complains that it's lost the connection to the phone and that I should try again! It keeps doing this 😞
Anyone know of any fixes, or had any similar experiences? I've tried it on Vista x64 and XP virtual machine.
tomblacknight wrote:I've got an N96 using the 12.* firmware, and I'm trying to update to the 20.* version.The NSU begins the update, turns the phone off and then complains that it's lost the connection to the phone and that I should try again! It keeps doing this 😞
same problem with mine, so i just updated using the OTA update.
Try to update your firmware once again and make sure that it gets completed.
munkiii wrote:same problem with mine, so i just updated using the OTA update.
OTA update tells me that there are no updates available. NSU says that firmware 20 is available :S I'll have a crack later today.
