Nokia 5800 Internal memory
1 replies · 5,631 views · Started 12 May 2009
Folks.
I am new on this phone and i am trying to convince myself to buying this phone.
I would like to know if the internal built in memory is large enought for installing lots of apps.
Is there any difference whether instaling apps in the internal memory or in the external one.
Thanks guys
sebita wrote:Folks.
Thanks guys
There's usually about 80MB free after booting up and with no apps installed to internal memory.
Symbian Apps rarely need more than about 8 to 12MB to run, so there's plentyof RAM available for multiple apps loaded at once.
Generally speaking, install things which run all the time (task-managers, virus scanners, email apps, etc) to internal memory
- this prevents an error when you try to activate Mass Memory mode with the USB cable and some app is locking the card.
Install everything else where possible to Mass Memory - in the UK the 5800 is supplied with 8GB Micro-SD card, so storage space is not a worry.
