Folks, is there a card reader app out there for the 5800?
Card reader application
sebita wrote:Folks, is there a card reader app out there for the 5800?
I'm not sure you need one. You certainly don't if Nokia PC Suite is installed. I don't know what happens if you connect the 5800 to a computer without Nokia Suite, though I would suspect it would might still be recognized as a flash drive by windows. I don't have another computer here at the moment to try it out.
I meant presentation cards reader. that is: you take a pic with the phone to a presentation card and automatically it fills all the contact data for your phone directory.
I was told WM devices have it
hello all
Mobile Stream Card Reader allows to use Palm-powered handhelds as an ordinary USB and Bluetooth card reader for quick and easy file exchange. It has the unique ability to export the card in the background mode allowing you e.g. to transfer MP3s simultaneously with web browsing.
