Forum Nokia regularly publishes example applications; they are intended as examples for developers, but occasionally are useful enough to be downloaded and installed by consumers. New today is Route, a basic GPS tracking widget. AccuWidget, an existing WRT example, which shows weather forecasts, has also been updated. Both widgets support miniview, which means they can be added to the homescreen of the Nokia N97. Miniview is something that all widget developers should consider implementing.
anyone know where I can get teh config for a specific place for the weather app? e.g. I want manchester rather than London but I can't find how to get the correct config to enter?
Found the answer myself, go to www.accuweather.com Choose Forecast-Quick Look. EWnter teh city you want in teh International option for outside the USA. click Go
In the next page look at teh URL in teh address bar and youy will find the code you need embedded. In my experience it doesn't remember the Custom location so I expanded the zip and edited the .html to swap out New York for my own chosen specialty. zip it all back up and you are good to go.
