E51 SIP(Internet) call and Voice call issue
2 replies · 10,756 views · Started 14 May 2009
I have configured SIP profiles in my lovely E51. I used to make a lot of SIP calls using wifi connection. It works great. But I have a problem.
In a scenario when I am in a Internet call and an incoming voice call arrives, and if at this moment I press any key, the phone hangs and restarts.
If I do not press any key untill incoming call is missed, my SIP call continues and phone works perfectly.
What can be the issue? Thanks in advance.
And yes, I am using my original old firmware because earlier I didn't feel any need to upgrade.
Device Details:
Model: E51-1
Device Software Version:
100.34.20
29-09-2007
Type: RM-244
Nokia E51 (231.01)
wecaz wrote:Hi,
Device Details:
Model: E51-1
100.34.20
29-09-2007
Type: RM-244
Nokia E51 (231.01)
I am having a similar problem with the phone dropping incoming calls on the same SIP device. Does anyone have a solution???
RS
mobiletech wrote:I am having a similar problem with the phone dropping incoming calls on the same SIP device. Does anyone have a solution???
RS
Hello, My problem is specific to a scenario when I am in a SIP call and one incoming call arrives from GSM network. If I try to perform any operation on My Nokia E51 at this moment, E51 hangs and restarts.
I avoid doing anything until incoming GSM call is missed and I continue talking in SIP call.
