Nokia N79 and Nokia N85 firmware upgraded to v20.175
23 replies · 6,794 views · Started 14 May 2009
Following on the heels of the Nokia N96, the Nokia N85 and Nokia N79 have both received firmware upgrades to version 20.175. The new firmwares has the usual bug fixes and application updates; the major additions are turning controls (flip to silent for incoming calls and alarms) and internet telephony set up, email wizard and email notifications on the active idle screen.
Great to hear.
This may be a bit off topic but does the n85 have the metal membrane that helps increase the lifetime of the OLED display
Hmmm...well for my already sold off N85 a firmware upgrade can't fix a crack under the d-pad, a wobbly slider, the bottom half of the fascia coming off, lousy speakers, or a keypad scratched up by simply using the slider, can it?
Long live N95 8G...
I just upgraded my N85 and it keeps resetting the home screen - cycling about every 2 seconds. The phone works and I can make calls but I can't use any applications. Help!
I've just reflashed it from Software updater and its still doing it.
any thoughts???
SM
@gibberishy.... i just sent my n85 off for repair because of that crack under the d-pad. looks like i'm not alone with that problem. since i have a NAM version, i guess i shouldn't be expecting an upgrade any time soon.
Just tried to update my N85 (via both OTA and NSU)... but not finding the update! Why not?
Hello!
Thanks for the info! Can't wait to update. But I want to ask a question: My N85 is the UK one but I use NSS changed the code and now I have Taiwan N85 firmware, if I use the build in application to update the new firmware will be in Chinese or English? Just want to check... Many thanks!!
chenliangchen
If you changed your product code and updated your firmware before, then i guess the new firmware will be in the same language as the old one.
car_guy143 wrote:chenliangchen
Thank you! I'm going to have a test...😊
If you speak english though then i would suggest the EURO1 product code555817 as that's definately been updated.
Can't find an update to my NAM N85 either. I've tried OTA and using Nokia SW updater. It shows the current version the same as the one on my phone as 11.0.47. Any ideas??? It's a Nokia N85 (RM-334).
I also just checked the device software updater page at europe.nokia.com/A4305060 and got the following:
Latest available software for Nokia N85, product code 0574476
Version: 11.047
Compare numbers
If this version is greater than your current software version, update now to get the latest features, applications and improvements. Go to Nokia Software Updater download
The update isn't instantly available to all users of all product codes i'm afraid. It can often take time i'm afraid.
have been using the new firmware for an hour and it works very well!
the share online seems updated and I got a new dictionary application, it's even not conflict with the old one, wowow!! and I can still use the traditional chinese. car guy 143 you are right! 😊
I'm lucky today, nokia has update for my taiwan firmware, when I was using N93i and N81 there was no update for traditional chinese at all. This time nokia seems has improved...
@Smurphboy
Updated my N85. Encountered some issues :-
1) Could not open contact..
2) Cycling of menu..
I did my usual dumb approach.. (took out the battery & sim card) (didn't really help). Got it all sorted when I did backup restore from the memory. That seems to work. Hope this help.
But overall, looks like a good update. Spiffier download (hints of things to come?). New features (as mentioned above) and hey.. a dictionary. Cool!!
To all those who have updated to FW20, Format the phone once. All the issues are resolved, plus some new changes will become visible.
When i updated FOTA, all the bookmark folders were still there. Also, the special icons for Music & Utilities were gone.
I reset the phone once, and flashed it via NSU too.
The fresh start was excellent.
* All the download bookmark folders are gone.
* The phone number of the caller is also displayed along with the name of the contact.
* I think new icons have been introduced in the Music Player.
Many more changes, will post them later on.
The new v20.175? firmware completely disabled my phone. It cannot boot up and cannot be read by the pc suite. I will try to fix it myself but probably will have to take it to the Nokia shop and wait for a couple of weeks for them to reinstall the firmware.
i did update my n85 firmware...
i expected it will be better than before...
untill when i wanted to post to flickr(share online)... the phone reboot/restart itself many times..
haih...
I had backed up my phone and then updated the firmware for the first time for v11 to v20. After updating, the special icons for Music & Utilities folders were lost. Then I did a hard reset and got back my music and utility icon. I lost activated ngage games and other 3rd party applications so I restored to saved backup file which i did before the firmware update and now I have again lost special icons for Music & Utilities folders. What do i do now?
The problem is even if i repeat I must restore after a hard reset otherwise I will lose my ngage application and activated games with it and also other 3rd party installed application.
Phone: N85
I just had the same problem, the home screen kept reseting every two seconds.
In my case the problem was in the mail application that couldn't start up properly (in the new version the home screen shows the last email in the mail box).
I have managed to change the stand-by mode to "basic" (no shortcuts or links on the screen),
and then I removed additional nokia email application that was installed on my phone.
Changing of the settings of the phone with continuously resetting home screen was not easy but it is possible, you just have to catch the right moments for pressing the buttons.
Good luck.
* Phone number along with Contact's name - On incoming calls, the phone number of the caller is also displayed along with the name of the contact.
How the hell do you enable this?
I've updated my N85-1 to V20 and HARD formatted it, still no luck getting this to work?
I live in Saudi Arabia, one of the countries that Nokia decided to block flickr service. They only used to offer Vox and Ikbis in v10 of N79.
I had to use the flickr cfg file to install flickr support.
After 20 update, vox and flickr profiles are gone. I can only add Ikbis now! No Vox even. Nokia support claims "regional restrictions". Flickr support said that's bull****.
the flickr cfg file is "corrupted" by the new shareonline.
i tried to setup my email in my nokia n79 but failed. I had been using hotmail in my previous 6500s but I can not use it in N79. The error message is "Server Not Found". When i click on Nokia Email Service Client, the error shown is "Installation package not found. Check that memory card is inserted". When I use nokia email settings, the email account is set up but i can not retreive any emails. It just says "Incoming Server Not Found" Why?
