Can I buy TomTom navigator 7 and install it on my Nokia 5800 and use it?
Is tomtom nav compatible with 5800?
asleo wrote:Can I buy TomTom navigator 7 and install it on my Nokia 5800 and use it?
Once again, the old Tom Tom question!:argh:
If you try using the search function, you will find numerous other posts on this subject, all culminating in the answer of.......
No.
Tom Tom has not supported symbian for about 3 or more years now, and are not planning to in the near future either.
Sorry.
