music menu popup
1 replies · 4,253 views · Started 14 May 2009
hi!!!
i own an n70 music editoion....the music menu keeps popping up every time i make or receive a call.
along with this the loud speaker gets activated and at times the call is automatically cancelled.
sometimes calls get rejected automatically.and i get to know that when i check the received calls list.
the key '4' is automatically pressed.even when the keypad is locked....
i tried formatting memcard thinking it was sme virus but that dint help...problem persists even without memcard...
help me...PllllZZZZZZZ!!!!:con?:con?😡😡
If Settings ->Phone->General->Original phone settings option wont work you can format the phone to its factory state.
To do this follow these steps:
1. Power Off the phone
2. Press and hold call 3 and * keys
3. Power Up the phone but don't release the keys until the phone prompts you to select your location...
Didn't work? Try again! It's a little hard to keep pressed only Call 3 and * keys
NOTE: This method will erase everything from the phone memory so it's best to backup your personal data before doing this.
vijesh_b_n wrote:hi!!!
