Antivirus Software
3 replies · 4,406 views · Started 16 May 2009
Hey Symbian User!
Is there an Antivirus Software for the Noka 5800. Would have preferred Kaspersky but obvoiusly there is no version for the Nokia 5800.
Other suggestions? Did you test other programs?
Would be very happy to get many replies.
Many thanks in advance
B.
Blubbele wrote:Hey Symbian User!
B.
The generl consensus is that Virus Checkers are not really needed on Symbian Mobiles - just be careful in your usage - don't accept bluetooth connections or email attachments from unknown sources.
Blubbele wrote:Would have preferred Kaspersky but obvoiusly there is no version for the Nokia 5800.
B.
Kaspersky IS available for the 5800 if you look hard enough - I had a trial myself for a while, but took it off after the trial expired.
Strange though, the official Kaspersy website says it's NOT compatible....
Things that make you go hmmmmm....:frown:
I agree with the above user though, you shouldn't need it unless you're browsing the web and going to dodgy sites!
