Nokia E75, remote access to Apple's Mobile Me iDisk
2 replies · 7,398 views · Started 16 May 2009
If you have an Apple Mobile Me account it is now possible to access your iDisk using the Nokia E75, (or any other S60 FP2 device)
iDisk is basically a 20GB online harddrive, instantly accessible from your Mac, it is ideal for storing files online that you might need to access when away from your computer.
Sadly the Mobile Me web interface doesn�t work on the S60 webkit browser, however if you have a Nokia E75 it is now possible to access your iDisk direct using the new �Remote Drives� function.
1. To setup your �Remote drive� from the homescreen go to - Menu/Ctrl.Panel/Settings/Connection/Remote Drives
2. Click Options/New Drive
3. Name your drive, I called mine �iDisk�
4. Now add the settings
Address: http://idisk.mac.com/your mobile me username
Access Point: Pick your access point, I left mine to �Always Ask�
Username: your mobile me username
Password: your mobile me password
5. Now click back
6. Now click Options/Connect, if successful it will return back to the Remote drives screen without a warning, there is no connected indicator here.
