HI.
Does new Nokia Phones E55 or E75 supporting outgoing line2 ???
Is there a possibility to change the Product Code ???
TNX again.
Regards.
HI.
TNX again.
Regards.
Which product code support ALS - second outgoing call ???
I am still searching for product code, wich supports ALS (line2) on Phone E55 or E72 ???
Now I use N97, but the phone S.X.
Rooki wrote:I am still searching for product code, wich supports ALS (line2) on Phone E55 or E72 ???Now I use N97, but the phone S.X.
I had an N97 and sold that, got fed up with it, now got E72, but don't know which Product Codes support ALS - there is a long list of ALL E72 Product Codes, might take you some time to work your way through them all!!
I have the Time, but dont have this two Phones to try it out 😊
When I know that ALS works on E55 or E72, I will buy one...
Is there anybody, who has a Phone & the spare time to try out this Product codes:
E72: 0587333, 0591306
E55: 0580935
TNX again, Regards.
P.S.: ALS switch option is in: Menu, Settings, Calling, Call, Line in use (LINE1 or LINE2) or you can try to hold down the key #
