So i found an MSN app for the P800.
I found it on an Arabic forum. There was nothing but " msn for P800 " and the attachment.
I obvioulsy downloaded,installed and used it. All works fine,perfect.
I also obviously really wanna share it with y'all.
But since I also want to give credit to the programmer and also dont want to cross any lines. For all I know, the programmber may have wanted his app to be released
I am waitin for the green light from an Admin or Mod.
Till then,every one be patient (:
Regards,
What does this app do? The least you could do is share that with us.. :roll:
MSN
Micorsoft Messenger Network.
Lets you use msn on your P800
I take it your talking about PalmMSN available at my-symbian.com, I tried it, TipicME is a much better product in my opinion, and it supports more than just MSN with a better GUI.
Is it compatible with the P800???
I've downloaded it, but it's just a bunch of files.....
loooooose files....
I went to this Arabic forum ... but yeaa!!!
how can i install this app ... what should i do with all of these files
please tell me the steps ... and i would like to know ... can i access the MSN messenger network via WAP Connections ?
You have to use a GPRS connection to use MSN messanger. You will not need to go to your wap browser anymore. I dont know the connections/configs yet becasuse my P800 is arriving in a few hours but I had an MSN messanger ap on my CLie Nr70v also and it worked great via Bluetooth memory stick to the T68i over a GPRS connection.
Please advice me where this Arabic forum is so i can try to use a translator so we can find out if the arab who posted this really wrote this or just post it or whether he wrote it and is telling eveyone to download it and try it 😉 I would love to have this ap also.
Been using TipicME.. Works fantastic. Best around atm for sure.
You can get it here
http://www.tipic.com/node.php?id=1394
Hope that helps..
screen shots dont look like msn messenger to me?!? 😊
Beggers cant be choosers mate.. 😉
