Samsung PC Suite (updated version 7.7.2.20.9) is available to download from http://uk.samsungmobile.com/supports/softwaremanuals/software.do?phone_model=GT-I8510&sw_type=SW
The main changes are the updating (from Nokia) of Samsung's PC suite to the same codebase as the current Nokia PC Suite 7.
Note: If the installer fails or seems to be taking a long time (more than 5 minutes without doing anything) then uninstall ALL Samsung PC Suite components, including the CDMA drivers; then restart your computer and re-run the new installer.
Samsung PC Studio 7.2.18.9 only this version:con?
Samsung PC Studio 7.2.18.9 only this version????
the are and others versions !
stuclark wrote:Samsung PC Suite (updated version 7.7.2.20.9) is available to download from http://uk.samsungmobile.com/supports/softwaremanuals/software.do?phone_model=GT-I8510&sw_type=SWThe main changes are the updating (from Nokia) of Samsung's PC suite to the same codebase as the current Nokia PC Suite 7.
Will this mean that I can have both Nokia and Samsung devices syncing to the same PC at long last?
The battery is not as long as possible, no protection circuit of the battery is full of that should stop charging, or battery for heating or overheat impact performance
