9210e upgrade
4 replies · 2,231 views · Started 12 April 2002
I am thinking of upgrading my 9210 firmware but does the cd rom need updating as well?
If not will all the cd rom apps work ok?
thanks for you help.
mark<font size=-1>[ This Message was edited by mbjoinery on 2002-04-12 2239 ]</font>
yes you do need somftware upgrade as well. what version are you using?
anyways you can find all the software updates ie. All_Nokia_Data.sis at the nokia forum site.
All you should do is download both the all_nokia_data & All_nokia_memory_card_data .sis files & load them on.
Actually the nokia service centre should do all the upgrades for you, but never the less you should know.
ciao
HyPeR
Err...is it possible to upgrade the Z ROM(12Mb) to the size of 9210i? Would it be diffcult??
By the way, though mine is v3.18, I still can install and play games of v4.18 firmware like Bounce, Card game, etc.
I am running v3.62. how much does nokia charge for the upgrade and will my local service centre link telecom be able to do the upgrade?
