Will nokia release the N97's firmware on the Nokia 5800, as i have seen videos on youtube with the N97 running the 5800's firmware?
cheers
cheers
Most probably not. Also, don't believe everything you see on YouTube.
Really looking forward for it.
The firmware is not what im bothered about, its the home scReen, i want to see the facebook screen update manually and have widget support...
It's not possible.
Will Nokia do somthing similar, because its a waste of the 5800 because they are both touchscreen ?
N97 has some very nice improvements on 5800 firmware. I already wrote to nokia (not sure if that makes any difference) and asked if it is possible to add some of the n97 firmware specialitys.
