Just a quick question, I'm not sure if it's been asked here yet (Have looked and not found anything...
Where're the GPS physically located on the N97? I know on the N95 it was behind the zero key so you had to have the phone open to get a good lock, but is the N97's positioned in a better place?
If anyone can get the n97 manual online it will show the location of all the antennas. It most likely will be located along the edge of the screen like the 5800 and all the new nokias. I wouldn't worry about this as nokia seems to have fixed this design flaw.
Just for completion, thanks to AAS bringing to light the N97 User Manual, the antenna is located in the top left of the device.
It's shown on page 80 of the N97 Manual: http://nds1.nokia.com/phones/files/guides/Nokia_N97-1_UG_en.pdf
Thanks RogerPodacter for confirming it's in a better place than the N95's 😊
