E75: Do not want to sync subfolders...
3 replies · 5,053 views · Started 26 May 2009
I have set up the connection between the E75 and my company's Exchange server. To my surprise it works pretty well (even though not as well as on Windows Mobile) 😊
After about 24 hours of use the phone has now synchronised every e-mail in every subfolder which must be a nightmare for the system. Is there any way I can set MFE to synchronise only selected subfolders or only the Inbox?
Many thanks!
/Martin
Yes, there is.
While you're in the MFE inbox, click on options, settings, what to sync, and at the bottom you should see a setting for folder subscriptions. At that point, simply scroll down and click on the ones you don't want to synchronize and then exit out.
An alternate way to do it is to scroll up until inbox is highlighted, click on that and scroll down to more folders and click on that, then click on options, folder settings, and that'll take you to where you need to go and the last part of my instructions apply.
Strange. I don't have those options in my version. I can only choose "Sync e-mail" (yes / no) and "Remove older than..."
Firmware was upgraded about two weeks ago...
// M
murbeck wrote:Strange. I don't have those options in my version. I can only choose "Sync e-mail" (yes / no) and "Remove older than..."
// M
You're right, my mistake. You can only do what I mentioned with other mail accounts in MFE, but not for the actual Exchange account on the E75, which is strange.
My apologies.
