The rather brilliant N-Gage-exclusive 3D platform game Bounce Boing Voyage has been updated to include motion control on those phones which have accelerometers, where you can tilt the phone to control the main character (or you can use the traditional button controls if you prefer). If you've already bought the game you can get the updated version free, and if you haven't bought the game you can buy it from the N-Gage showroom tab. Instructions for updating existing games are below.
Just updated. The controls are shockingly bad. Dont bother updating.
Ok I dont know if its just me, but this update seems to have broken my version of bounce. When I fiddle around with the options screen, my 'back' and 'select' key do not work, meaning a have to do a forced close.
to avoid any problems, first thing you do when you update is: options menu --> keys --> set to default..... ok youre ready! you will not find any problem! this implementation is really good! i loved it! and the loading times are reeeally shorter now! thanks nokia!
@ Powerbacon
I did that. Then I tried to press 'back' to exit to the main menu. It didnt work!
Is anyone else having control issues?
i had... then i did this solved my problem =[
You need the latest version of the N-Gage application to use the accelerometer controls. I will have more information on the official N-Gage blog today.
@powerbacon:
It worked for me! Thanks for the tip!
I came across this forum by chance and discovered this is one of the best thread ever. Thanks u guys so much for the information you give. So cool.
comparatif simulation assurance vie multisupport - simulation assurance vie ! Les sites de simulation assurance viecomparatif simulation assurance vie multisupport
