I've read somewhere that someone has been able to get this working on the INNOV8.
I know there are other programs Available such as Virtual Radio and Bee but found them to be not the greatest.
Does anyone know how to get Nokia Internet Radio working on INNOV8 and if not, can you recommend any good Internet Radio application?
You'll have to hack the device with HellOX to be able to install Nokia apps in your Samsung phone.
Try Mundu Radio http://radio.mundu.com. It's not as good, but may do what you need.
RickyS wrote:You'll have to hack the device with HellOX to be able to install Nokia apps in your Samsung phone.
Thanks for the suggestion mate. I downloaded the Mundo App. There are not many channels on it and you cannot input your own so I'm going to go down the hacking router and see if I can get Nokia Internet Radio installed as it's far superior.
I'll be cartwheeling if it works!
Thanks 😊
