Jules_N93 wrote:Stuclark, you probably mean this response:"1) You are right about camcorder sound, it is using AMR Narrow Band at 8000Hz 16 bit 2 channel 12.8 Kbps bit rate. There are several factors leading up to that decision, and as always there are trade-offs too - AMR is felt to be a better choice for human voice - using the AMR software codec they are also able to get better noise reduction - and using the software codec they get better management of the load using the ARM CPU."
a remark made by a guy working at the Samsung UK HQ.
If you call this a 'valid' reason, you're either on the Samsung payroll, or don't take filming seriously. I know you have a I8510 Stuclark, which has the exact same problem. Have you ever had a Nokia and used that for filming? Haven't you noticed the enormous difference in audio quality? Have you even seen the review here on AAS, where the I8510 gets 4 out of 10 for filming, because of the crappy sound?
It's to bad that the moderator on the Samsung part of the AAS forum is always defending Samsung, even if there are serious problems like this, or like the battery problems with the I8510. This forum is supposed to be by and for the users! It's not a Samsung advertorial!! Take this request seriously: AAS, use your contacts to adress this with Samsung.
There's a couple of points in there I need to address...
Firstly, NO ONE on the AAS team is biased towards either Nokia, Samsung, SonyEricsson, Motorola, LG, or anyone else making Symbian based phones! Sure, we all have our preferences and those may differ from one person to another, but each device gets rated on it's own merits; not on which manufacturer its come from. No one is on the payroll of any company, and contrary to popular belief, we don't all get free handsets from everyone either (I wish)! It should also be noted that I'm not "the moderator on the Samsung part of the AAS forum" - if you look in the Nokia, Motorola, SonyEricsson & Sendo parts you'll find just as many posts from me. (and more moderating tends to go on there, as the more popular boards attract more spam, unfortunately)
To be honest, NO, I don't take filming dead seriously - if I did I'd invest in a decend, dedicated camcorder, as that will always beat a phone's filming abilities. That said, I have done a lot of testing with my 8910; although I know full well that my usage pattern will mean I won't use it as extensively in the future.
So, I guess it doesn't matter as much to me... but what does matter (and what Steve really slated the 8510 for in reviews) is the audio / video syncrohisation. I can confirm that on the current UK (Orange) firmware, the audio sync problems which plagued the 8510 (and still exist in that handset) and early 8910 prototypes have almost been eliminated. Even on "full" HD recording mode, the audio lag is acceptable. (in actual fact, the audio gets ahead of the video, due to the time it takes the phone to compress the video)
...which brings me to the next point... the one, stand-out comment from the Samsung guy was "and using the software codec they get better management of the load using the ARM CPU" - remember that when trying to encode HD video the phone's processor has a HELL of a lot to do. The phone's not running a top of the spec Intel i7 processor, so doesn't have loads of power to spare, so if there's something that can be (reasonably) reduced in order to reduce the load on the CPU, then it's quite legitimate to do it!
Oh, and yes, I have got many Nokia handsets, and yes, I do notice their strengths and weaknesses. In fact, this weekend I plan to do a couple of comparison videos on my 8910 to compare to some I took on my N95 a year or so back... (I'm also going to do some comparisons to videos shot on my 8510)
