I have problem about keyguard unlocked!!!!!
5 replies · 14,572 views · Started 30 May 2009
"Use keyguard switch to unlock screen and keys"
It just happens , how i gonna use keyguard i don't get it.
help me plzz... , i can't do anything with my phone right now.
Bigbossman wrote:"Use keyguard switch to unlock screen and keys"
Seems to me like you need to R.T.F.M my friend - Read The F.... Manual!!😊
There is a switch on the right hand side of the phone - slide it down and let it go.
The screen and keys will either lock or unlock and you can use your phone!
Hey Presto!!:banghead:
@Mafty- this post is not useful. If you cant answer a question/don't understand the question then simply dont reply. Insulting in forums is not big and it is not clever.
@Bigbossman- I have the same problem with my phone, when i try to use it I get the unlock message and when i flick the keyguard switch nothing happens. I called my phone provider and they are going to repair/replace the phone for me. This is a fault with the handset as far as I know, so get it replaced!
Peace
DK
yeah well to be honest the poster did not give those details. if he said "help my key lock button is broken, i slide it but nothign happens!" then that would made things clear. instead he just said he cant unlock his phone, kinda sounds funny.
RogerPodacter wrote:yeah well to be honest the poster did not give those details. if he said "help my key lock button is broken, i slide it but nothign happens!" then that would made things clear. instead he just said he cant unlock his phone, kinda sounds funny.
I agree with the above - the question was a bit cryptic to say the least!!
and @DiscoKiller - I think the post was perfectly useful - it explains exactly what the original poster was apparently asking. As for insults, there were none.
You want insults, you keep acting like the forum police and you'll get some from me!!
