Move SMS to Memory card from phone memory
3 replies · 5,354 views · Started 31 May 2009
Hi....
Being my first post here... First off got to say ... great forum.. been helpful a lot..
I have not see a solution my current problem though..
I have SMS on my phone memory .. around ( 800 )
and i know once it reach 1500 its gonna slow down the fone...
earlier wen i got to 2000 msgs i transfered them to phone memory... and its now in a folder .. which is saved and fine..
but that option is not showin ( move msgs to phone memory )
how can i move the 800 msgs in to the phone memory folder without overwritin the current 2000+ msgs in that...
Thankx in advance
If the move msgs option is not being displayed, Nokia must have removed it.
I assume there is no option within PC Suite on your PC to backup/restore/move SMS messages?
same problem with a friend of mine. she set the sms saving to memory card. but when she clicked the msgs in the inbox, sent messages, it wont open.. we already tried restarting the phone, reinserting the memory card, formatted... still same problem. but when set to phone memory the sms can be opened..
S60 has the obstinate specification of allowing (only ! ) 999 SMS messages to keep in storage . You can , however , multiply this to another 999 messages .
The messages are stored in a HIDDEN folder in C: (the device memory) by default . When you are reaching the 999 limit , go to Messaging > Options > Settings > Others > Used Memory , and set it to MemoryCard (= E: ) for another 999 messages .
To be able to view all the messages , sadly you need this Used Memory setting again .
When you have a PrinterOption , you can store messages as a Printout : this is not recommend , since this uses a lot of Memory .
I don't know , but I suppose there is a workaround in PCSuite on your computer .
Because I don't use SMS a lot , my settings for Messaging is on MemoryCard anyway , to save DeviceMemory .
😊 Regards jApi NL
