I purchased an E90 off ebay
It was on 02 but it is unlocked, calls, texts all work fine
How do i set it up to use my t-mobile interment connection? , everything is a default to o2 internet
cheers
cheers
Try the "Settings Wizard" on the phone. If the phone does not have the settings wizard, see if it is downloadable on the E90 support pages on http://www.nokia.com/support
Otherwise, call T-Mobile customer service, and ask them to send you the settings as a configuration SMS (then you open the message and save the settings as instructed on the screen).
Check also if T-Mobile has a service on their web site, where you can order the settings to be sent without calling them.
