Bluetooth profiles for 7650
2 replies · 2,721 views · Started 12 April 2002
At the http//www.forum.nokia.com site on the Bluetooth section you can find FAQ information on what Bluetooth profiles are supported on 7650. Site requires free registering / login. Information was updated 9.4.2002.
Profiles supported in 7650
-GAP
-SPP
-OBEX
-DUN
-FAX
-OPP
-FTP (phone as a server?)
So no audio supported there -> no wireless headsets or hansdfree kits!! Otherwise looks quite good I think. Just waiting to get hands on my 7650.. and trying then to establish Bluetooth communications to my PC and iPaq 3630 PocketPC device with BT exp. pack.
Cheers,
Pylon
Facinating, but it kinda puts the Bluetooth functionality outsite the use of the normal bloke though, doesn't it?
Nevertheless, I still want one!
in answer to pylons message, it's a good point about the bluetooth profiles ! there is no headset support, are nokia really serious surely theyhave made a mistake, it would be unthinkable to not support headset connections with a phone of this calibre especially when they re;ease the new nokia bluetooth headset, what a pairing it would make !!!
cheers
Clifford
