Nokia N95 Installing and Removing takes too long!!!
3 replies · 6,956 views · Started 02 June 2009
Ok so the phone works great, it's fast enough and has enough memory but there is a problem....Whenever I want to install an application it takes a long time to start the installation process but when the installation begins it goes pretty fast. The same thing happens when I go to delete an application it takes forever for the removal process to begin. Did anyone have a similar problem and maybe someone has some tip for it???
Mine's the same way. It's probably not a bug. Just a weakness. It is a little annoying. But not enough to make me lose any sleep.
galore01 wrote:Ok so the phone works great, it's fast enough and has enough memory but there is a problem....Whenever I want to install an application it takes a long time to start the installation process but when the installation begins it goes pretty fast. The same thing happens when I go to delete an application it takes forever for the removal process to begin. Did anyone have a similar problem and maybe someone has some tip for it???
You created a thread in a forum about this??
Over-react much?
