Need driver for SD M2 memory card
2 replies · 7,534 views · Started 03 June 2009
Hi everybody,
Can anyone help me to localize the driver for the removable SD M2 card reader ? I am a W960 and P1i user, Now it seemed fun to me to install the removable card holder inside the W960, so i swapped both the memory cards with each other, only thing is , both phones cant read their new memory cards xD .
ANY help would be much appreciated, i got X-plore and CapsSwitch installed on both phones, so if i can manage to copy/switch both drivers from the phones, its gonna make me sooooo happy ^^
thnxs in advance 😃
Your question is a bit unclear/confusing . Since you talk about SD , M2 and xD , I suppose you are asking for a Driver on the Phone to be able to use a CardReader for reading/writing . As far as I know this doesn't exist . I am waiting also for this possibility for ages . The main reason , as I understand , the connection plug on the Phone , e.g. USB , is a Passive connection . But you can connect the Phone to a computer with an Active connection . The computer can read/write the MemoryCard , connecting the Phone or a Cardreader to the computer .
When you just want the Applications on the other Phone , why not download it again from the internet ?
😊 Regards jApi NL
Nice idea, but thats not what i mean. I need the P1i driver (System file) to convert my W960 into a W960 WITH M2 memory card (support). Only thing is (i got both phones, a P1i and W960) i cant localize the driver in the system files,otherwise i could swap them myself using Xplore and Capswitch.
thnxs for ur reply anyways 😃
