I just got my nokia and im really bad with technology. I tried to connect to my univ wifi, but it would not connect, nor does it ask for username/passowd. The univ system uses WPA2 and AES.
All help would be appreciated.
thank you
thank you
tuxson82 wrote:Hi,I just got my nokia and im really bad with technology. I tried to connect to my univ wifi, but it would not connect, nor does it ask for username/passowd. The univ system uses WPA2 and AES.
thank you
Try this:
Settings -> Connectivity -> Destinations -> Access point (Add new acc. pt)
Choose the automatically find access point option and then fill in the details as they come up. That should do it!
