Just purchased the Nokia 5800XpressMusic. The salesperson copied all of my contacts to the SIM card in my old phone then inserted it in the 5800. I could not load the contacts into the 5800 from the SIM but was able to do this quite easily using Blue tooth.
The issue now is that I have a constant blinking message that SIM memory Full.
I cannot find a way to access then SIM to clear the memory. Not sure if this will even help clear that message.
I've looked through past posts but canot find this issue.
With kind regards and thank you for your help.
