aifbuilder
4 replies · 2,294 views · Started 02 March 2003
Hi i would like to deploye my java app on the se P800
for that i have to use the aifbuilder that builds files to launch my app.
but when i click on the generate button of the aifbuilder, i got the (cpp.exe has returned the error code 2)
what's wrong with that tool?
I worked that one out the hard way too!
You must uninstall the entire SDK and reload it but this time select everything from all the options along the way, even C++!!!
Then it will work!
[quote="roddefou"]Hi i would like to deploye my java app on the se P800
what's wrong with that tool?[/quote]
Open up a DOS shell and type
devices -setdefault @UIQ_70:com.symbian.UIQ
Then try launching 'aifbuilder' again.
