The quirky and charming Java-based arcade puzzle game Go! Go! Rescue Squad! is available in Ovi Store and we've been taking a look at it on the Nokia 5800. To see our review, along with a ten minute gameplay video and lots of screenshots, head on over to the Go! Go! Rescue Squad! game page on Ovi Gaming.
As it says in the review, some of the levels are REALLY difficult, mindbendingly tricky. I could have sworn some were broken due to a bug, but it turned out I just wasn't thinking laterally enough.
If you get stuck you might want to read the partial walkthrough on Pocket Gamer (only do this if you're really really stuck though, otherwise it spoils the fun of playing):
http://www.pocketgamer.co.uk/r/Mobile/Go!+Go!+Rescue+Squad/review.asp?b=tips&c=13051#tips
Yeah, the learning curve is very steep indeed. I think this is the only game where I've got stuck during the tutorial.
That said, it's very fun indeed. Reminiscent of Exit, but less actiony. The trick is to not get overwhelmed by the options available at the start of a level, but to try something out and see where it goes wrong, then adapt your strategy to solve the problem. Again and again.
Definitely, it feels like they've built the game around the assumption that people will use the rewind option a lot.
I hope they do a slightly less steep curve next time though, a lot of people will get put off if they get stuck straight away, which would be a shame.
It was a huge walkthrough supplied by the developers. Mobile Game Faqs have got the complete walkthrough split across two pages:
From beginning to Deathtrap Towers 4
http://www.mobilegamefaqs.com/hints.php?id=2605
From Deathtrap Towers 5 to the end
http://www.mobilegamefaqs.com/gameinfo.php?id=2605
That should help if you're stuck on the last few levels 😊
