SonyEricsson actually thinks...:)
2 replies · 2,048 views · Started 03 March 2003
Just recieved the HCH-32 Car Holder for the P800 the other day. In my car I already had the HCA-20 handsfree-kit, and the HCC-20 System Cable, together with the HCH-28 Car Holder for my old T68i.
Not only is the System Cable the same for the HCH-32, but SonyEricsson has actually provided the same mounting system for the two holders. This means that you can actually just snap the HCH28 out, and put the HCH-32 right on the same bracket...
If only everyone made it this easy...😃
I like this to, but unfortunately the system-components themselve cost very much.
I think that 30-40 EUR for a simple piece of plastic is too much!
BTW: The 50-60 EUR for a USB-Cable is much too expensive as well!
[quote="opheim.com"]Just recieved the HCH-32 Car Holder for the P800 the other day. In my car I already had the HCA-20 handsfree-kit, and the HCC-20 System Cable, together with the HCH-28 Car Holder for my old T68i.[/quote]
How do you like the HCA-20? Worth the money? Does it come with audio mute or do you have to purchase it separately? Did you hook up an external antenna?
