BugMe...
6 replies · 1,867 views · Started 03 March 2003
I've downloaded a trail version of BugMe from http://www.electricpocket.com and installed it in my p800. Infact it's a nice and useful program. But it seems it has got a Bug. When I tried to enable to sound an alarm, it says:
"setAlarm
file doesn't exist"
When I try to put a voice clip, it says:
"Program BugMe
Reason Code: KERN-EXEC
Reason Number 3"
then the application exits by itself.
Has anyone tried this and do you get the same messages?
MaxLinux,
no probs here. Works fine for me. Try to uninstall BugMe (in applicationa view) and reinstall it again in main memory.
I find the main problem is that BugMe has to be running for the alarm to sound. This might work ok if we get a port of that app that allows you to specify programs to start when the phone is booted but until then I would have to manually start BugMe to be reminded of things.
Shame as it's a nice piece of software.
C
Hi Guys -
On the above:
1) At the moment you need to install BugMe! on the C drive otherwise it will not find some files it needs. A fix will be out very soon.
2) We are working on adding auto-start to BugMe!, it should be in the next release, hopefully this week or next...
If you have any questions or suggestions for future releases of BugMe!, please do not hesitate to drop me a line: [email protected]
Thanks,
Iain
I hope they set the release pretty soon. I just purchased Bug Me and i already love it. Very useful, and with the improvements, it will be great 😊
