n70 work only agenda or calendar and how to stay continous connect
1 replies · 2,678 views · Started 09 June 2009
hello i have nokia pc suite 7.1 and ivt bluetooth soleil 64 249
some aplication in nokia pc suite is working like folder optio ; mesage ;image music but some aplication not - calendar; contacts because he cannot connect wath i moust to do because apear error on nokia pc suite and all the is disconect to the port cannot conect to the phon
just i want to work only agenda or calendar and how to stay continous connect to the port
thankyou
Hi sony8943,
Do have backup of your phone data & PC registries then
Uninstall Nokia PC Suite, Nokia Connectivity cable driver, PC Connectivity solution, Nokia flashing cable driver(if any on your PC), Run PC Suite cleaner. Install latest Nokia PC Suite from europe.nokia.com/pcsuite, reboot your pc. Once pc started, connect your phone and check 😊
