Energy Profiler
1 replies · 2,030 views · Started 09 June 2009
Hello Everyone,
I'm trying to use the Nokia Energy Profiler to check some PPM numbers but the thing is I cannot install it in my platform due to some certificate stuff (I'm using s60 5.0).
Do you know if it's possible to have a Nokia Energy Profiler but in *.sis (not signed) format instead of *.sisx one? I guess problems come from here.
In other question, do you know if there's another SW (energy profiler) available? Where can I get one?
Thank you in advance for the help.
Regards,
Humberto
You can find energy profiler at forum.nokia.com,
You have to switch off certificate check on your phone inorder to install the app.
Cheer,
