oK so picked up a 5800xm today and just when i got home to try out wlan to connect to my home network, the wifi is not detecting anything?? when I go to menu>settings>connectivity>wireless wlan>wlan wizard starts the network search but it never stops searching! I even tried letting it search for an hour still keeps going, its really annoying the heck outta me..what is wrong? is this common? please come to aide:con?:con?:con?
5800 wlan problem
imM3an wrote:oK so picked up a 5800xm today and just when i got home to try out wlan to connect to my home network, the wifi is not detecting anything?? when I go to menu>settings>connectivity>wireless wlan>wlan wizard starts the network search but it never stops searching! I even tried letting it search for an hour still keeps going, its really annoying the heck outta me..what is wrong? is this common? please come to aide:con?:con?:con?
Is your wireless router set to hidden? If not, then no, what you are experiencing is not common.
i dont think so..my pc at home detects alot of wifi spots since im in apartment complex..is there a setting for this, thought it detects automatically?
You have to log into your router settings and enable the wireless radio. You also have to enable your "ssid" to broadcast.
can you or anybody here guide me thru set up wifi manually..much appreciated TY
just go walk around and find an unsecured wifi spot and test your 5800 and see if it connects. my 5800 connects to my wifi out of the box, just one click and it was connected. couldnt have been easier. are you new to wireless routers and such? i would imagine your router has wireless turned ON by default, cant imagine otherwise.
imM3an wrote:can you or anybody here guide me thru set up wifi manually..much appreciated TY
What brand is the wireless router that you have?. All the things you need to know about setting up the router for wireless connectivity should be in the documentation that came with the router.
If not, I can most likely help you if you state the brand of the router. You would use your computer's internet browser to log onto your router, and change settings.
