copy files from PC via wifi - possible ?
6 replies · 6,917 views · Started 12 June 2009
I understand that I can't use PC Suite via wifi. I wonder if it's possible to copy files from the PC via wifi ? Possible ?
dez_borders wrote:SymSMB 4.0 will do this also.
Telexy is no longer offering SymSMB. I think they were required to pull it off the market due to some issues regarding the ownership of the code base.
i've downloaded TVersity. But I don't understand how it helps me in copying files across a wifi network ? Can help explain ? Thanks very much.
typee wrote:or download and use media server software, such as TVersity, which is free 😊
N/A wrote:Telexy is no longer offering SymSMB. I think they were required to pull it off the market due to some issues regarding the ownership of the code base.
Thanks for correcting me (although note SymSMB 4.0 is still available if you look hard enough).
