Is it possible to autostart lightsignalplus? i can't see the option anywhere so yeah... any suggestions?
there's an app you need to install which runs anything you want on start up. Its called like auto start or something. Just google and you will fine it quickly.
Google for "PowerBoot" - you can get it from Ovi, too. It's free.
oh alright! thanks for the suggestion.
yeah i just found it and it works perfectly! it's a bit hard to differentiate between all the different apps though. raw system names lawl.
thank you!
