E75 with Windows 2000?
7 replies · 5,601 views · Started 13 June 2009
Hallo,
does anyone uses E75 together with Windows 2000 to syncronize contact and schedule?
As that I can't change operating system, it would be nice to know, whether it will work. On homepage from Nokia operating system XP and Vista are listed.
Nokia PC Suite or Ovi Suite do not install on (support) Windows 2000. I don't know of any PC to phone sync solutions that support both the E75 and Windows 2000.
You can export/import contacts separately via .vcf files from within the Contacts app.
Thank you for this information.
Contacts are not the problem, but I'd like to syncronize schedule every day.
You can synch with a remote service, like Google Calendar, or some SyncML service on the net, if that's enough.
I've just read on Nokia web pages, that there is a special version available, i.e. "Nokia PC Suite Enterprise Edition". This version should run under Win2000 as well.
Maybe this info will help other guys.
In google, search for Nokia PC suite 6.85.14.1 sort of PC versions, if i remember correctly, 6.85.x version of Nokia pc suite is compatible with Windows 2000 :icon14:
I have talked to helpdesk from Nokia. They told me, that Nokia PC Suite 6.xx is no more compatible with E75. But I haven't tested yet.
For how inexpensive memory runs today just upgrade your RAM to at least 1GB. If your PC cant handle at least 1GB of RAM then you dont want Windows 7 to run on that PC. You will run into a lot of probems with 512MB.
_________________
Auto news
