Hi guys,
around 6 months ago i debranded my n95 8gb by changing the product code and doing the update using nokia suite. I dont think i changed this code back.
Im looking to get it unlocked, i will probably just take it to one of the usual "we unlock all phones" places and ask them to do it.
1- Will the fact that i have debranded cause any issues whatsoever?
2- do i even need to tell them i have debranded it?
3- should i change the code back before to what it was originally before i ask them to unlock it?
Ben
mbenz1 wrote:Hi guys,around 6 months ago i debranded my n95 8gb by changing the product code and doing the update using nokia suite. I dont think i changed this code back.
Quite a common misunderstanding / common questions 😉 De-Branding and Unlocking are totally unrelated.
For warranty purposes, both de-branding (Firmware) and back-street shop unlocking (Network) invalidate the warranty with Nokia.
I am not sure if Nokia engineers can tell a handset bas been unlocked with a hacking tool or not. However, Nokia most definitely CAN tell if firmware has been de-branded
to answer your questions:-
1. No
2. No
3. Not a good idea - if you change the code back, NSU may attempt to downgrade the firmware next time you use it and 'brick' the handset.
Hi Dez,
Cheers for your response. much appreciated. all i needed to know. cheers
Took my debranded N95 8Gb to my local shop "Dr Unlock" and he did it in minutes. I confessed to debranding it and he said "Yeah I know I can see both the old product codes and the new one you put on." He connected some sort of gizmo in place of the battery that was plugged into a laptop.
My phone is out of contract/warranty so I wasn't really worried. My assumption was the backstreet guys must do that many of them they're not really bothered.
