Hi
I am trying to install OPL on my PC and am confused.
I installed an S60 SDK from Nokia and carried-out the following from the OPL readme file.
Unzip this zip over the SDK, so that the Symbian folders align.
That is, the contents of \Binaries\PC\Symbian are copied into
your D:\Symbian folder (where D is your Series 60 SDK drive).
Now, I have two folders under C:\Symbian. The one with the Nokia stuff is called 7.0s and the one with the OPL stuff is called 6.1. Should I combine those two folders? What is a good tutorial to start with? Where do I start?
Your help is greatly appreciated.
Regards
Patrick
