WPA /TKIP wifi
6 replies · 5,773 views · Started 17 June 2009
Hi there
I am trying to connect to a wi-fi that is encrypted with WPA. The Omnia HD can see the network but won't conenct. Has anyone managed to connect to a similar network... and if so how did they do it? I'd be greatful for any help!
Many thanks
Elly
The phone is not connected at all. It can see the network but will not connect to it. Any ideas?
Oh right I see what you mean. Yes it connects to other networks, so it isn't a problem with the electrical bits (I don't think!)
Now you know it�s not a phone problem. And with that specific router, other devices connect well?
As long as WLAN Security Mode on the phone is set to "WPA/WPA2" it will use TKIP (or AES if it's a network running WPA2+AES) since it's a protocol which is used by WPA.
If you set it to "WPA2 only" it will only allow AES or TKIP+AES encrypted networks since theese are the ones used by WPA2 (not 100% sure about this since I haven't bothered to test it out).
A requirement for getting any of the above working is of course that you know the networks PSK (PreSharedKey). And of course, you have to make sure that your network isn't running with a MAC address filter (would guess this is quite rarely used in corp.networks..) and that it doesn't use an auth.server. If so, you'll have to change WLAN Sec.Mode to "802.1x".
- Stolen from the N95 forum from a while back .. please use Search .. a lot of this stuff has been gone through by older s60 handset models.
