Hey there people, I have a slight problem with call divert, at least I think that's the problem...:con?
When I get an incoming call it automatically gets diverted to nowhere...just gets cut, and even before it rings, but it says missed call, and I end up with like 20 missed calls...
I have no idea why this is happening, does it have anything to do with divert?
Also what does the small face icon that's next to the numbers in contacts mean ?
Any help would be appreciated,
Cheers,
~TheSaladMan
Firstly you could reset factory setting (in settings menu).
If this doesn't work, I would synchronise your contacts with PC Suite, then format the internal memory with *#7370# (and then re-sync your contacts).
Hopefully one of the above will cure the missed calls issue.
The face icon in contacts is where you could attach a thumbnail pic of the caller (if you already have a photo of them).
Factory reset sorted this out on my brothers phone.
