Shortcut menu
2 replies · 5,153 views · Started 20 June 2009
Hi All.
How can i access the shortcut menu so that i can put some shortcut on the widget, like the nokia 5800. Please help.
While on the homescreen, choose options -> edit content and then add either shortcuts 1 or shortcuts 2 (or both, if you'd like). To change the shortcuts, tap on the shortcut widget on your screen and choose "Settings".
Hope this helps.
