Hi
I am trying to update Nokia N96 firmware from nokia.com but every time i tries to update it gives me error. I believe that cell phone came with T mobile firmware. any idea how to update the firmware from nokia's website.
EDIT: i am noob when it comes to technology but i believe that what i really need is to debrand my n96... so please help me
You can use Nokia Software Updater on your Computer . Also use Nokia PCSuite to keep all your data complete .
When you get an update error , it will be that it is a T-Moile branded Phone . The Productcode is the key .
In case you like to UNbrand it you can use Nemisis on your computer .
But : Phone warranty expires !
Here is the sticky link about productcodes :
http://www.allaboutsymbian.com/forum//forum/thread/76359/
Otherwise you have to wait a bit until T-Mobile has the new version ready .
😊 Regards jApi NL
I am using this phone in Pakistan and in my country we don't have T mobile service and i don't have any warranty so i think debraning it won't do any harm 😊 i have absolutely no idea what to do.. so guide me please
Here is a link , found through Google :
http://clear-nokia.blogspot.com/2007/05/nokia-n95-debranding-guide.html .
Nokia PCSuite + SoftwareUpdater you can get at Nokia.com .
Another thing is to get a Productcode that you would like .
Hope it helps .
😊 Regards jApi NL
Cateye wrote:Hi
If using NSU, always disable your PC firewall program during the upgrade.
can u plz tell me how can i format my cell fone...
Nokia E51
1) go in Menu to MemoryCard > Options > Format .
2) Do the Vulcan Death Grip , see my post here :
http://www.allaboutsymbian.com/forum//forum/thread/81021/
Or read :
http://www.allaboutsymbian.com/support/item/Sorting_out_an_endless_reboot_cycle_after_rogue_application_install.php
Now all personal data are erased . Phone is Shop Clean .
😊 Regards jApi NL
